My cbr has a stock dampning set up.
It works pretty good on the streets.. But when Im riding hard or racing & I come into a turn with the rpm's high & let off ...
It seems to let go, causing my bike to shake a little ?
Not sure if I can adjust it or should I get ride of it for new one ?
Any & all help is welcomed.. :idunno:
It is based off of speed , unless you buy the HRC race ECU (which allows it to be adjustable but costs a ton) you will have to switch to a manual one like GPR. I had my 07 for 3 days before I ripped the stock one off and put a GRP on it. Came into a turn kinda hot but easy doable and the damper was at almost full stiff, almost made me not make the turn.
The Damper is much better on the current gen ('08 - '11). I spent the entire first season on the track using it.
That said, I am in the process of swapping mine out for a hyperpro RSC as the stock unit is not keeping up with my pace at the track anymore.
