i need to change the top triple clamp for my 929rr, left corner is bad & i have a new one, so can i loosen the fork bolts & take off the center nut, will this bother the forks at all, any help will be awsome, will also be changing bars:idunno: thanks.
if you are just changing the top bridge it should not bother the forks, simply just loosen the bolts to forks, looseen the center nut and off you go. your gona also have to swap your ignition switch since its bolted from underneath onto the top triple and while you have it off might be a good time to change your clipons if you are planing to do so.:thumb:
