On a normal fireblade, how much does the clutch arm move when the cable actuates?
Thanks
James
Thanks
James
Not very much, the external arm that the cable connects to probably moves an inch or so (5cm?) when the lever is pulled. It's not as much as you would think.
Great stuff, thank Ian - I was expecting a fairly significant movement but will give it a try as is
Sorry for not giving all the info Spaz - CBR900RR
No worries J, I actually just went and measured it because I had 900 withdrawal. :rotfl: been laid up after some surgery and needed to see the old girl. It's actually less than what I said. It was only like 1 to 2 CM depending on where exactly I measured it. It's barely any at any rate.
Crikey that's much less than I expected, I'm glad I asked before ripping everything apart! Many thanks indeed
