1 - 14 of 14 Posts
I got a 98 F150 4.2 V6 with a 5-speed (work truck). . It has a class 3 hitch and trailer brakes. Anyway I was wondering how big of a boat I can tow with it. You have to keep in mind that the boat will have to be launched and pulled out of steep and usually wet ramps. I know traction is a problem with what I have witnessed at boat ramps sometimes. Maybe better tires would help :idunno: . I would like to get an old Formula PC-28 but I think it is about an 8000lb boat. I'm pretty sure that is too much for the F150 to handle.
What's the towing capacity of your truck? Have you looked in the owners manual? It's probably not much more than 5,000lbs. I wouldn't try towing more than 3000lbs with it. Get a truck with a bigger motor, automatic tranny and 4wd if you want to tow.
:twocents:
Look on your door jamb, the GVWR is there on the decal. I think you need more truck. My '03 F-150 with the 5.4L is rated for 8k lb towing capacity. That would include the trailer and such. I wouldn't push it with the limits. The tongue weight alone would probably ground your truck.
I attempted to move a 20' enclosed trailer (car hauler) with my truck and it damn near drug my hitch with the trailer loaded with household junk.
More truck (diesel heavy duty) or a smaller boat?
While we are on the subject take a look at THIS contraption... :idunno:
Not that this is any good....
A buddy and mine used to tow a 32ft Bayliner with an F150 and a V6 Motor...... We were only pulling it about 12 miles each way.... We did get stuck on the ramp once and thank goodness for a guy with a diesel dodge dually.
did he say powerstroke
how many woodchucks could a woodchuck make if it could? More importantly, what does a woodchuck look like if a woodchuck was out in the woods in the daylight?
Err...maybe we shouldn't go there.
Back on topic. You need a bigger truck. Or if mechanically inclined, a bigger engine.. Personally, I'd choose a Kenworth.
1 - 14 of 14 Posts
