1 - 9 of 9 Posts
I finished the rear hand brake on my 2000 CBR 929, this is an easy mod. The hard part is getting the right parts and arranging them right. I did this mod for less than a $100, this can be done on most bikes exactly the way I explain here. Of course you could easily buy a $300 brembo hand brake kit and have great results too, but that's too expensive.
Parts (labeled and pictured later):
-Tear drop style rear master cylinder junction valve
-48” of brake line
-A Front brake master cylinder from a late model bike with a remote reservoir (so it can work flipped upside down on the left clip on)
-An extra M10x1.25 banjo bolt to connect the 48” line to the adaptor
-3” of tubing to allow the front hand brake reservoir flip upside down.
-Dot 4 brake fluid
I ended up flipping the clutch and HB levers (clutch lever over HB) for better use... originally I thought the other way was easier.
Again: I ended up flipping the clutch and HB levers (clutch lever over HB) for better use... originally I thought the other way was easier
It works better flipped with clutch lever over HB... that's what Real stunt riders do:)
1 - 9 of 9 Posts
