1 - 2 of 2 Posts
I was looking at the maps from Power Commander. They have one for Jardine slip on, and one for Jardine RT-One High Mount. My pipe say Jardine RT-One, but how do I know whether to choose the SLIP ON map, or the RT-One HIGH MOUNT map? What exactly makes a high mount different? Any suggestions on which map to use?
Thanks alot!!!!
The high mount systems if Im remembering correctly arent going to scavenge the exhaust gases as well so the bike is going to run a little richer because of it so the power commander map for the high mount will probably be a little leaner (less fuel) than just the standard slip on. If you have just a standard slip on than go with the slip on map. And remember you can always change out the maps as you please so even if the slip on one doesnt work for you try the high mount map. Its a bit of trial and error to find which map works best with your bike.
1 - 2 of 2 Posts
