1 - 2 of 2 Posts
Could someone please help me understand how to test an ignition switch on a 2000 CBR 929rr (US)? I'm not getting the fuel pump to turn on. Additionally, no lights except on tach. So far, tested the relays for the engine stop and fuel pump. Fuel pump also working. Next step is the ignition, but I can figure out if the ohm reading above 3. is to high when test one set of wires (four prong connector). Please help this electrical stuff is killing me. If I ground the tank I can get thing to work...
thx
Banned
So that says the switch works as far as power to the switch and power out. That too says ground at the switch has to be attached to complete a circuit. Check any fuses?
When you ground it, do the lights come back on too?
1 - 2 of 2 Posts
