That looks great! Yeah I'm not sure how much is missing under all the crap. I'll drain the fluids and get into it more. Suppose I could buy a cheap damaged bottom crank case from ebay and cut one of the good tabs off it, then it will be the same spec material and bolt hole. I appreciate the photos and the feedback.I had to repair the case on my 99 track build. It’s documented in here somewhere lol. I used a small chunk from a bad CRF450 engine case a buddy had lying around. In hind sight, I should have used something a little thicker, but it worked. Had it professionally welded in, then I shaped it and it worked pretty good. The build in my signature is a link to it View attachment 110541
