Okay I've had the new rear for what 8 days and guess what
another f&*n flat. I do not believe my luck what have I done wrong.
And I have made sure to stay in the lane etc etc and only use clean roads.
maybe on the lucky side (is there one) it's a clean hole so should be able to be plugged.
Make sure you/they use an umbrella patch (from the inside). Most shops here in the U.S. won't even patch tubeless MC tires 'cause of liability reasons. Same happened to me when I had the F4i - 90 miles on the bike and I ran one of those big-ass double headed nails through the rear, heads first! Great luck, eh?
Watch your speeds on a patched tire, and check pressure often. Also check to make sure the plug isn't coming out. The one tire I had to patch started losing it's patch after a little while.
