1 - 2 of 2 Posts
Well, I knew with an older bike, I'd have some kinks to fix. The next issue I have run into is replacing the ignition. I ordered the following kit that shows that it's compatible with my bike: Ignition Switch Gas Cap Cover Key Lock Set for Honda CBR900RR 92 95 919RR 96 99 | eBay
However, I noticed the plug on the base connector is different than my current plug. Which can be seen in the picture below. What will I need to do to first get the ignition switch off, and second get it wired in.
As to why I'm replacing the switch, it's currently loose and turning bumping the key causes it to immediately shut off. Also, the red ignition wire broke loose of the soldering.
Discussion Starter #2
It appears I'm going to have to remove the triple tree to get to the ignition. However, does anyone know the torque amount for the center bolt? I don't have a torque wrench, so this will be interesting.
1 - 2 of 2 Posts
