1 - 2 of 2 Posts
I know this forum pulls thru with uncanny regularity so I will give it a shot.
I need to find an IMS Pro Series Hot Rod part 427305. I have found 427306 and 427304 etc...
This is for a Yamaha outboard motor. Should be an 18mm wrist pin, 22mm big end pin and 116mm length. The closest I can find ia a Rotax rod but the groove cut for the oil to pass into the big end pin is cut wide and deep. This wont work for me as I need 3mm machined off both sides of the big end of the rod.
This Rod is going to put a 70mm kx250 piston into a lambretta racing cylinder.
Thanks for looking.
1 - 2 of 2 Posts
