1 - 2 of 2 Posts
Hi everyone,
I need some quick info regarding the installation of a full erion exhaust for my 954.
Is there anything special which I need to know before installing the exhaust? eg. Is it just the case of removing the old exhaust system and installing the new one?
Many thanks :)
My Arata was straightforward, hopefully your Erion will be the same. Get anti-seize for the header bolts, and high-temperature gasket sealer. Put a thin bead of gasket sealer on all pipes just prior to fitting them together or you may have leaks. I took the HTEV cables off of the servo motor up by the seat, just don't turn the servo, or if you do, put it back where it was or you'll get the FI light coming on. Good luck! :thumb:
1 - 2 of 2 Posts
