hi, just installed a devil 3/4 pipe on my 2002 954 RR.
FYI, cali version.
ive only owned the bike for approx. 1 month. have only ridden it a handful of times w/ stock pipe installed.
well what ive noticed is that after the install the bike seems to slightly bog below 3.5k rpm and then a definite surge in power occurs at 4k rpm. its very noticeable, and def was not there before the pipe install.
i rode the bike a good 150 miles with stock fuel map(have pcIII usb) and have recently installed a fuel map for the devil 1/2 pipe system found on the powercommander website. i havent given it a good test ride yet w/ new map but did take it around the block only to notice the same bog below 3.5k rpm.
whats going on? anyone else have a similar result? should i try another map?
also some pretty good popping occuring during decel. is the ike too rich? i realize there is a PAIR valve on the CA model.
FYI, cali version.
you should try the map fit for that pipe if you already have them just try more maps for the devil pipe..
