First, remove the clutch slave from the left side of the bike so that the lifter rod doesn't shoot out and take an eye out. Ok, chances are that won't happen, but lets get the pressure off of the back of it anyways. There are 3 8mm bolts holding the slave on, and one 8mm bolt holding a bracket that has to be loosened to release the top of the slave. You can let it hang there. The goal is just to release the pressure.
Auto part Engine Fuel line Automotive engine part Automotive fuel system
Next, remove the six 8mm bolts holding the clutch cover on. Gently remove the cover and secure the o-ring. It is recommended to replace this o-ring after removal and mine was stretched after removal anyways. It is up to you if yours is in good shape and you want to reuse it.
Auto part Engine Automotive engine part Carburetor Clutch
Remove the six 10mm bolts and springs that hold the pressure plate in place.
Auto part Clutch Engine Wheel Locking hubs
Next, remove the lifter piece and lifter rod from the center of the clutch assembly (circled in red above).
Remove the seven clutch discs and six plates from around the clutch center. Keep them in order to make reinstalling them easier.
Unstake the clutch center lock nut. This can be a little tricky. I ended up digging deep into my toolbox to find a tool able to get underneath the stake and pry it up enough to clear the lug. Then remove the 30mm clutch center lock nut. You can use the special Honda tool (or 3rd-party equivalent) to lock the clutch center in place, make one from instructions off the internet, or use an impact wrench at about 50psi and knock that puppy loose! I did the latter (thanks abtech!) and it came off without too much trouble or time.
Auto part Clutch Engine Gear Transmission part
Auto part Engine Automotive engine part Wheel Automotive wheel system
Remove the clutch center and special washer that was underneath the lock nut. Make sure that the thrust washer stays in place.
Auto part Engine Gear Clutch Automotive engine part
Install the studs on the JTR clutch center. They are reverse threaded and have 7mm heads. I donm't have torque specs on those so I tightened them by feel.
Auto part Rotor Clutch part Machine
Next, install the new clutch center, slipper bearings, clutch center upper, and spider spring. I found it easier to preasseble everything on a horizontal surface because the bearings tend to run on you. Make sure that each of the six bearings stays (circled in red below) in its raceway as you install the upper over the studs. Then drop the spring in place. Hold the whole assembly together and slide it in place. Install the special washer and the new lock nut on and run it in to keep the clutch center assembly in place. Lock the clutch center in place and torque the lock nut to 94 lb. ft.
Auto part Wheel Cylinder
Auto part Clutch Wheel Engine Bearing
Reinstall the clutch discs and plates in the same order you removed them, remembering to install the top plate in the shallower grooves.
Auto part Clutch Motor vehicle Gear Bearing
Reinstall the lifter rod and lifter piece making sure to reinstall the rod the correct direction.
Install the pressure plate and hold in place with the six 4mm allen head bolts and springs. Bottom the bolts out and give it a turn to make sure they're tight (thanks greyhound!). Any more and you're buying new bolts!
Auto part Clutch Engine Automotive engine part Transmission part
Reinstall the clutch slave and tighten them down. Bleed your clutch line to make sure that no air got in during the installation. Give the clutch lever a pull and visually make sure that the clutch basket releases.
Auto part Fuel line Engine Vehicle Automotive engine part
Reinstall the clutch cover with the o-ring and tighten the six bolts in a crisscross pattern.
Auto part Engine Metal Automotive engine part Vehicle
Check your oil level, keep your fingers crossed, and fire her up! You should be ready to go!
This is very good instructions, i might try this , but im not sure if should do the whole clutch assembly.
Im not sure what i did to mine but, pulling the clutch slave off,(installing a new sprocket) I pulled the rod clutch lifter out too far, i might off misalign or lost the spring in the clutch assembly?
I have clutch lever pressure, but in any of the gears, i cant disengage the clutch off the gears. Help me!:idunno:
Check the slipper balls I bet you got one out of place. That or you missed a washer. It has been a bit but I seem to remember a thick washer/spacer that stuck to the OEM basket when I did mine. With the same result.
Weird, i pulled the cover on the clutch assembly and watch the operation of the clutch moving. Looks good, so i pulled the 6 springs and pressure plate. Eveything looks good and aligned. threw it back together. started it, getting the new oil warmed up, and i just remember, i need the new oil ran through the engine. that might of set the clutch in place with new oil.
Worked like charm! went through several motions with the clutch lever w/ engine running. Got better response w/ new sprockets and chain 15/42.:thumb:
