I have had to push the bike home a couple times due to the bike kept cutting out when put into first gear. I know what you might be thinking but, I have now checked out the side stand switch and clutch lever switch and every thing seems fine, and it has just done it again to me. (Thankfully outside my house, so not too far to push this time.)
I have a power commander fitted and have decided to dis-connect it, and it seemed to cure the problem, but wandering if this is just coincidence.
Could a power commander cause this problem and if it can is there a way to check the power comander unit out to see if it is a wiring issue with it etc. I was also getting the 19 code flashing which scared me a bit because this is the code for the ECU, but the code also dis-appeared when the power commander unit was unplugged.
I have checked most of the wiring loom and again a few nasties I have found I have fixed by using new connectors etc.
Just wandering if anyone else has experienced this and what they done to fix a similar problem?
