1 - 20 of 20 Posts
· Registered
2000 honda shadow Ace 750 22,xxx miles aftermarket pipes LOUD bike has been doing fine,,, i tool it on a 2.5hr ride each way,,, i had my head phone in on the way there and on the way back i could hear a knocking sound, very little but could hear it Dosen't match the RPM but more like knock,,,,,knock,,,,,,knock so i started to play around a little ,,,,,,,i realized if I start out in "per say" 2nd or 3rd gear from take off you could REALLY hear it , but with the pipes and traffic i could hear it but not the best...,,,,,,,,,,,,,,,,,even in 5th gear running 55-65mph i could hear it knock,,,,,,,,,,,knock ,,,,,,,,,,,,knock,,,,it sounds like its coming from the lower left side ,,,,,,,,,,,,i dont know a TON about bike,, it the shittest part was i have the bike up for sale and now this happens,,,im not the kind of person to put a bandaid to make a quick $2000 .......so please advise on what i can do to narrow down or help somebody else diagnose... i do have a youtube account if i need to make a video....couple weeks ago i took a 2hr trip each way and i swore i could hear a knocking sound but didnt want to belive it ,,,now i know somehthing is true......thanks again friends ,,,,j bursby
· Registered
Hi, could you lift the bike off the ground with paddock stands rotate the wheels and check the chain rotation in the front sprocket area, if its a knock and not rpm associated , then it could be something catching:smileBill
· Heeza Y Zasch
From your description Bursby, sounds like Bill may be on the right track. My guess... your drivechain and sprockets are beat. Check chain slack with your manual (or Google it), and assess the teeth on both sprockets. A loose chain, under a load, will make a knocking or banging sound, but usually the rider will notice a momentary hesitation of acceleration which accompanies this. Wearing headphones could somewhat "mask" a rider's sensisitivity to this.
If a loose drivechain is your culprit, you may get out of it by proper adjustment. If it's not a chain, perhaps having an experienced rider of a friend ride along side of you, listening for the noise, would also be a good option.
Good luck and keep us posted :thumb:
· Heeza Y Zasch
any images of the sprocket(s)?
that chain does look rather overdue for some tightening, cleaning, and proper lubrication. no, WD40 is not a proper cleaning agent NOR lubricant :nono:
· President: Team Full Chat
heres some pictures....yes that is a doulbe A battery... i seee that is way too much,,,, would that cause the knocking noise
Where you are measuring the chain (and the visible slack shown) would lead me to believe that your chain is EXCESSIVELY loose.
You should try to get the measurement at the mid point between sprockets.
And yes, a chain with excessive slack will knock on the swing arm/engine case like crazy.
· Registered
Discussion Starter · #9 ·
i will pop the covers off tomorrow it is dark outside,,, and am currently working on my other truck also,,,, after thearing the head off and replacing the lifters i find out that i have a rod knock,,, so i am at a loss of what to do either put more money in to fix and then sell or sell as is and lose $1000 to $1500 off my asking price,,,,, i have over 2700 in parts alone in the truck,,, new tranny ,,new head ,, and evry new part i could buy for the motor when i had it taken out the truck,,,just really up set rode the bike and heard a bad sound then get the truck all put back together and now have a verified rod knock,,, with the possibilty of the crank being no good either ...
· Registered
Discussion Starter · #10 ·
please let me know what you need me to do,, pics vids and i will be glad to do so... ive had the bike a year or 2 now,,,,the bike just had new tires put on about 6 mobths ago,, and the shop said the tightened the chain and what not,,,, i think that alot of slck for 6 months,,,, i will get good pics tomorrow of the front and rear sprocket,,and chain,,,,im adduming the fat guy before me nver had them changed,,,,
yes i know wd 40 is the best lube for chainn hahhahahhahahah just kidding,,, my other bike is a 97 cbr f3 and boy did i learn alot,, i own the haynes ,,,chilton,,,clymer books....i like to read
· Registered
Discussion Starter · #12 ·
u nslow1;1699233889 said:
my advice... dump it.
put a fair price on it ($1200-$1500) with full disclosure.
whats the disclosur ,,, "chain might be lose here take my bike for pennies " wtf kind of respone is that not looking for WHAT YPIU WOULD do ,, but rater what is wrong so i can fix,,, did you miss the part of motorcycle repair this isnt MOTORCYCLES FOR SALE
· Heeza Y Zasch
so what's with the "so i am at a loss of what to do either put more money in to fix and then sell or sell as is and lose $1000 to $1500 off my asking price" :idunno:
· Registered
Now you've done it Casey:huh:
cb7guy I would take the time to clean the **** out of that chain, inspect it along with the sprockets and lube everything up good . An overly loose chain will make a lot of noise and wear the sprockets quicker than normal. You can adjust the chain just as it states in the manuals that you have for those other bikes or youtube it. If it's not the chain then we can move onto the next thing and you will have possibly increased the retail value just be cleaning that thing up.
· Registered
:plus1::plus1: That chain is as loose and dry as a 50 year old h**ker...
It's definitely making some noise, even if it's not the only problem. Get it fixed before you throw a chain and turn a little problem (hopefully) into a catastrophe!
· Registered
whats the disclosur ,,, "chain might be lose here take my bike for pennies " wtf kind of respone is that not looking for WHAT YPIU WOULD do ,, but rater what is wrong so i can fix,,, did you miss the part of motorcycle repair this isn't MOTORCYCLES FOR SALE
$1200-1500 is not giving away a 2000 Shadow 750, especially in the pictured condition. I have a buddy that picked up the same bike in mint condition 2 years ago for $1500 to use as a daily driver to keep the miles off his R1 and save the tires, and his back, for the canyons. He mounted some black ebay hard saddlebags for $200 to carry his lunch and jacket and it looks good. Not trying to be a d**k, just a realist. It's the 750, not the 1100, and the pic's show it's in rough condition.
I'm thinking about pulling the trigger on this one:
http://losangeles.craigslist.org/sgv/mcy/5954574351.html
  • Like
Reactions: unslow1
· Registered
Aside from the chain being way too lose (and you possibly getting sued / charged with murder if you sell it as is without full disclosure), there seem to be something wrong with your , and . keys.
1 - 20 of 20 Posts
