I'm looking for a Laser Sight Thermometer from Raytek. i want to know if all 4 exhaustpipes exactly the same in heat.
Wich one do you use in your shop
thanks,
It doesn't matter if it a cheap unit or not, unless you need precise readings it really doesn't matter. Since you want to compare the cylinders, it won't matter if the values or high or low.
