Not a fireblade question but i'm sure you folks know how to fix this.
One of the turn signals on my vtx takes a while to start flashing. the other side works as intended. It would make sense if the one didn't work all together but it typically has a 10-30s delay before flashing once activated. Both front and back bulbs work. I figure its dirt/corrosion in the switch gear and will clean that out but i didn't know if there might be something else causing it to happen.
