1 - 2 of 2 Posts
Rear caliper bleed bolt is leaking. front master was has now stopped is there some kind of thread sealant some one could reccomend i cleaned nipple very well even with some compressed air but still does it only after riding it ???
this is after running new fluid through system 05 1krr thanks in advance
The bleed nipples are tappered so tighten as you turn, are you doing them up enough and are they the correct ones, ie you havent fitted new ones. If you must use plumbers tape it will do the job well and cause no damage.If it was me i would get a new set and try them for the cost. Th e only other possible cause is they have been over tightened and cracked on the caliper but this is very unlikely.When you do tighten them only use two fingers then you wont over tighten them..Brake fluid should be changed every 2 years you might be boiling it you never know....
1 - 2 of 2 Posts
