I just found the ECM located behind the battery is leaking some kind of really sticky fluid? I don't think this is normal, Has anybody encountered this. It's a 1997 Fireblade
If it is leaking a brown sticky fluid it is the capacitors leaking. The capacitor physically leaks its liquid electrolyte which will cause a weak and eventually failing. My advice would to replace the ECM before it fails and strands you. Good Luck
