1 - 2 of 2 Posts
I've seen an R1 w/ LED's that he put into the corners of his headlights to replace his turn signals which I thought was pretty cool. What I want to do is ADD LED's into my headlight to compliment my flushmount front signals. It looks like there is a perfect round spot at the corners of the light about 3/4" diameter that I could drill the hole for...has anyone done this? If so, how do you keep the plastic shards from falling into the headlight when you drill a hole there for the LEDs? Also, how would I go about sealing this around the LED so moisture doesn't get into the headlight?
Thanks
1 - 2 of 2 Posts
