I was wondering if anyone knows what is different about the pazzo vs. crg levers. Also what do you all prefer long or shorty?
I've got the Pazzo shorties. I've only had 1 chance to try them but they felt pretty good. The long ones have a notch where they're designed to break away in a crash. CRG are a little more money, and I think they're offered with a perpendicular hinge like a GP lever.
hey Phobe, Did you have to readjust your clutch when you put on your pazzo levers?I just put on a set and the it seems to be alittle more grabby when I pull in the clutch to roll the bike...
Actually, the first time I took it out with the Pazzos I had crazy clutchslip. The master wasn't letting go all the way. You have to make sure to lube the little brass drum where the plunger sits. I just used some white lithium grease.
Didn't find it any more grabby though.
