I seem to have this mystery engine mis problem on a 2003 954rr I have spent thousands of dollars and still dont have a diagnosis shifted into 5th under a full load on the track and bike started missing it appears to be electrical w the ignition I am so frustrated
By stating you have spent thousands of dollars and still do not have a diagnosis, I'm thinking you have already been to the dealer?
I'd hit up Bladeracer, he's got a ton of now how.
I have talked to him already he was helpful I was hoping to find someone who has has had or fixed a problem like this
I am thinking I need to check the coil packs and ignition pulse generator its as if the bike is running on 3 cylinders they adjusted the valves and everything normal except the exhaust valves were out a little bit but normal wear it does appear to be electrical
