1 - 2 of 2 Posts
Hello-
Does anyone know if there is a full engine kit available for my '94 Blade? I am looking for gaskets, bearing shells, piston rings, etc.. It just seems odd to have to order every part separately when doing a re-build.
Thanks.
Hello-
Thanks.
I'm not aware of anybody that does rebuild kits for bikes like those you can get for car engines.
You should be able to order a complete gasket set but you need to order the bearings to match the rods and mains so a kit wouldn't include shells anyway. The bearing codes are usually stamped on the back and side of the cases, each rod and on the end of the crank. There are three possible sizes of main and rod journals, three sizes of rod bores and three sizes of case bores.
I just order the seals and gaskets I need rather than gasket kits.
1 - 2 of 2 Posts
