1 - 20 of 24 Posts
I had the blade on the rear stand to clean and lube the chain after cleaing the bike today and i happened to be holding the tire in place and noticed as i ran my rag across the chain and sprocket that the sprocket could move maybe a quarter inch without the wheel moving. I can hold the wheel still and move the sprocket forawrd and back just that little bit..
Is this a problem? I never noticed it before so I am not sure.. there's no side to side play like it's loose or anything just that forward/backward little bit of turn I can do with it. Just wondering if this is normal or if I need to get it looked at since it is under warranty..
Thanks for any and all helpful information
Re: Probably a stupid question but
That's the part I was trying to think of.. Ok, guess it's off to the stealer tomorrow to see what is up with it. I hope they don't give me any major run around since I bought the thing from an out of town dealer.
See now you got me wondering what would have happened today had it not been raining for the first half of the day and I had just gone riding the mountain roads like I had planned and not cleaned the bike till afterwords. I hope the cush drive is a covered item on the warranty.
It's a pretty straightforward job to inspect the cush. Sounds like you already have a stand...pop that rear wheel off and have a look... :nod:
  • Like
Reactions: Getsome
Not sure what to look for... i usually end up stopping at the shop where i get my tires when the chain needs tightening since they do it free and also clean/lube the chain for me. So I've never taken the thing off before. Also, I tried earlier to get the nut loose to take the tire off and that small ass piece of crap wrench they give you in the tool kit is so small i can stand on it and it won't budge. Gonna have to get a cheater bar to add to it I guess.
so if I do get this thing off myself what am I looking for?
Sorry for my ignorance but I just this year started actually doing things to the bike myself and some of these things make me want to ask questions so I dont' fuck it up... thanks for all help and advice... you guys are always the best when it comes to this stuff.
From your responce, Take it to the shop.
But if you were to get the wheel off the rim has several spaces in ther that accept small rubber thingies that cushion the sprocket assembly. One or more may be broken/Missing that need replaced.
OK, i see the rubber dampers that are in the hub in the picture of my manual here now that i got smart and looked into it. i am guessing those are what are being called the cush drive... guess it's time to see if I got a piece of pipe aroudn here that'll enable me to get this thing off.
You will better off getting a wrench or socket that fits rather than using the garbage tools that come with the bike. M2C
Just be careful to look at how the parts come off as they have spacers that might fall out and need to be put back properly. It helps if you have a buddy to help with re-assembly.
Just remember the spacers are supposed to go across the metal bars, like half in one piece of pie, and half in the other piece of pie. If the spacer has been inserted wrong, the whole spacer will be shoved into one piece of pie.
My local wrench guy says this sometimes happens. :idunno: Might be you're problem. I turn wrenches as much as you :D , but just trying to help.
Heck I turn wrenches every day at work but that's on industrial production equipment. I just finally decided this year I was sick of paying $40 or more per hour to get easy stuff worked on the bike.
I look at the manual and it makes it seem like i need a bunch of tools that i don't have. Only because this is a part I haven't ventured into yet that I am leary of screwing with it since I don't even know if this would be a warranted item. I am thinking that if it is just the rubber pieces that it'll be a non warranted item just because they would be expected to wear out just like the chain or sprocket..
was kind of hoping someone who's had this happen on a bike that was still under warranty would chime in and say it was or wasn't covered.
Guess I will see tomorrow as I have decided not to mess with it and take it down to the stealer after I goto court tomorrow. (No I didn't get a ticket, the guy who hit me last year, and didn't have insurance has refused to pay the insurance company so they are suing him and I have been ordered to come in to give testimony.)
If you're just taking the wheel off and the sprocket off the wheel, you need a 32mm socket to get the axle nut off and I forget what the sprocket nuts were (~14mm). The plastic cover and the rubber bushings will come right out.
The dealer will probably try to talk himself out of any warranty work.
Don't forget about the torque wrench to put it back on correctly. Not something you want flopping around back there.:nono:
dude, if its under warranty, just take it to the shop! Not saying you will screw it up but why take a chance if you dont have too.
If he is just inspecting the cush drive pieces, he won't need to remove the sprocket, as the hub/sprocket assemblies come out of the wheel together.
:plus1: I just went around the inside edge of the sprocket tapping with a rubber mallet/ wood block through the wheel (though this may not be the best way, mine was more than a year old). Can those rubber things actually break? They seem pretty fail-proof to me, just a block of rubber?
On a big HP bike, they can get pretty torn up. I have seen them in a hundred small pieces on our old ZXR750 stupid bike.
Discussion Starter #19
I ordered the rubber dampers today. The shop says with the small amount of play I have that I am fine to ride but it's a sign of the rubber getting worn out. So the parts will be here friday($50 friggin dollars, damn ripoff I tell ya) and I will be buying the socket I need before then to take her off and get them changed out... Thanks to all for the responses.
oh and it's a wearable part, not covered by warranty.
How many miles are on the bike??
I was just @ RonAyers.com. was the P/N you ordered from dealer 06410-MCF-000 ? $37.98 there.
1 - 20 of 24 Posts
