1 - 20 of 70 Posts
I've listed practically everything off the bike. I am located in CO. I have done my best to be as forthcoming about any wear/tear/issues with these items. Prices are negotiable. Please contact me if you would like to know if I have anything not listed OR you would like more detailed pictures of something, which I am always happy to do. Although I have done my best to link to the relevant pictures, the entire album can be found here for your browsing: shellcomplex's uploaded images - Imgur
Shipping calculation will be done on an individual basis with confirmation of delivery.
This part out will be posted across multiple boards, so while I will certainly be checking all boards as frequently as I can for PMs, you may be best off to email me at shellcomplex at gmail daught com for the quickest reply.
Also, please forgive my feet. They are big and hard to manuever out of pictures
Motor - top end (probably) needs valve seals, cylinder walls probably need a hone, stator case has light knicks, clutch case perfect, stator-harness connector is fried - $200 unassembled
http://i.imgur.com/e7LaA.jpg
http://i.imgur.com/QLSQM.jpg
http://i.imgur.com/LyzBL.jpg
http://i.imgur.com/enoXv.jpg
Coolant reservoir - $20
http://i.imgur.com/pni1t.jpg
Swingarms - one black one silver - $40/ ea
http://i.imgur.com/2Lwp7.jpg
http://i.imgur.com/i34fs.jpg
Airbox w/ K&N Filter - $60 w / K&N
http://i.imgur.com/4Ahy1.jpg
Frame - (shock not incl) clean CO title, $600
http://i.imgur.com/WZdnZ.jpg
http://i.imgur.com/7Hl4N.jpg
Subframes - 1 straight 2 tweaked 2 cut batt trays - $50 for clean, $30 for tweaked
Rearsets - red, Bohemian Racing, light knicks from use, comes w/ rear master - $125
http://i.imgur.com/sQiJj.jpg
http://i.imgur.com/CMNqe.jpg
http://i.imgur.com/4w1LI.jpg
http://i.imgur.com/L61Wb.jpg
Exhausts
Complete, Wrapped - $130
Complete, Not Wrapped - $130
Mid Pipe - $80
Dented headers - $20
Akra Can - $120
Custom Art Can - $80
OEM Can - $20
http://i.imgur.com/3ez4T.jpg
http://i.imgur.com/SfhqQ.jpg
http://i.imgur.com/CRtYa.jpg -\
http://i.imgur.com/AJlOf.jpg - These 2 are the art can
http://i.imgur.com/s0vDS.jpg
Rear engine mount - 1 black, 1 silver $40
http://i.imgur.com/PXIM5.jpg
http://i.imgur.com/4aOZl.jpg
Kickstand - $20
Master cylinder (front brake) - $30
http://i.imgur.com/bblDR.jpg
Passenger Pegs - light scratches, $20
http://i.imgur.com/eDGtg.jpg
Clutch Cable - $20
http://i.imgur.com/LjoUK.jpg
ECU - $150
http://i.imgur.com/bsAre.jpg
Wiring Harness - engine stator-harness connection needs to be replaced (cut off; melted), harness to reg/rect needs to be replaced (still connected but burnt from bad reg/rect)
http://i.imgur.com/Cfvym.jpg
http://i.imgur.com/5Xath.jpg - reg-rect
http://i.imgur.com/9fh0N.jpg
Exhaust servo - $20
Exhaust Servo + HTEV Valve - $60
http://i.imgur.com/BXZ10.jpg
http://i.imgur.com/dJItg.jpg
Rear seat - ylw/blk with "929 owner's manual" - $60
http://i.imgur.com/WazAR.jpg
Complete front end - Race Tech 1.1 or 1.2kg springs (can't remember which), will ship with either street fighter triple (modified 954 triple ready for fat bars) or OEM triple, no ignition, front
has BT016 w/ good life, l/r controls, master cyl, clutch, brakes+lines - $1500
http://i.imgur.com/mLMhp.jpg
OEM Triple - $50
http://i.imgur.com/L538u.jpg
Matching key ignition, gas cap, undertail (undertail has a running light issue on left side; brake-turn are fine; undertail needs cut batt tray) - $200
http://i.imgur.com/AnT0k.jpg
http://i.imgur.com/r415g.jpg
Brake Lock - $15
http://i.imgur.com/xPbYr.jpg
http://i.imgur.com/17KEO.jpg
Rear shock - with linkage, race tech stiffest spring (15kg) - $100
http://i.imgur.com/0K2x9.jpg
http://i.imgur.com/IiW3A.jpg
Gas Tank - a few places where a lowside took the paint down, METAL UNAFFECTED, no gas cap - $150
Ylw/Blk Tank Bra - $40
http://i.imgur.com/n27MT.jpg
Fairings
Chinese Fiberglass
Front fairing - a few tabs broken $100
Left Mid - $60
Left Lower - $60
Tank-front fairing (scuffed down to fiberglass where the hook under the gas tank-$20
http://i.imgur.com/ryayh.jpg
http://i.imgur.com/WtXAs.jpg
http://i.imgur.com/FAkiI.jpg
http://i.imgur.com/FZUSC.jpg
http://i.imgur.com/qP4W1.jpg
http://i.imgur.com/40bd6.jpg
http://i.imgur.com/7d2rX.jpg
OEM
Front Tire Cowl - $30
Front Cowl - few broken tabs, upper windshield mount - $80
Left mid - $30
Left lower - $30
Right mid - $20
Right lower - $20
Rough Tail - $20
Junk Tail - just pay shipping
http://i.imgur.com/PPwBJ.jpg
http://i.imgur.com/syHap.jpg
http://i.imgur.com/hExM2.jpg
Upper Fairing Stay Mount (bottom sold) - $50
http://i.imgur.com/y6Z8x.jpg
Headlight - Upper mounts broke - $250
http://i.imgur.com/Re6qs.jpg
http://i.imgur.com/YrhXg.jpg
OEM Pegs (brake side lever is bent/ground down a bit; no rear master)- $20 / ea
http://i.imgur.com/TXPkI.jpg
Clutch cover scratched - $40
http://i.imgur.com/jVSPa.jpg
Clipons - $40
http://i.imgur.com/yMiaF.jpg
Rough undertail - $20
http://i.imgur.com/i8y2h.jpg
Rough rear seat - $20
http://i.imgur.com/ybJLG.jpg
2 x Great condition front seats, no tears - $80 / ea
http://i.imgur.com/GPBHO.jpg
Instrument cluster - ~25k miles - $150
http://i.imgur.com/NkWOp.jpg
Bad Cluster - spedo only, no rpm, ~20k miles - $50
http://i.imgur.com/UWjrC.jpg
http://i.imgur.com/NjMD6.jpg
Rear rim + BT016 with good life - $200
http://i.imgur.com/KS8JY.jpg
Front sprockets - both 16t - $20 ea
http://i.imgur.com/nhP2j.jpg
Rear seat passenger strap - will include free if you buy a rear seat - $10
http://i.imgur.com/P9NO6.jpg
OEM Taillight - $20
http://i.imgur.com/SfNuO.jpg
Radiator - $125
Please let me know how much for lower stay bracket shipped to 19401. I only need the lower section that mounts to the frame and holds the headlight. Please I have been looking every where for it. Pm text or call me. Money in hand.
Thanks,
Kenny 516-303-4871
Thanks,
Kenny 516-303-4871
PM'd
1 - 20 of 70 Posts
