1 - 10 of 10 Posts
Hey so uhhh.... I'm back again guys. :thumbd:
I'm installing my new chain. Ya'll will crucify me for not doing the sprockets at the same time, and I know I know. I'm short on the funds so I figured I could get away with just doing the chain this year (23K on old one) and then when I finish school next year I could really give this bike a good overhaul.
So I installed the master. Haven't riveted it yet where you splay out the peen things. I have the end plate pressed on, and was just noticing how kinked the chain looked. Is there a chance I over tightened the master link when I pressed it in with my chain break tool? I ran the wheel around a few times, and the chain makes a noticeable "ghrhrhgh" noise when the master goes over the front crank sprocket. I took my micrometer to the links and compared the master to a standard link, and they are both within the same
spec mm. But it's so kinky!!!!
The weather up here is shitty and cold and school is keeping me from having some time and money to work on the bike and do it right. I'd like to at least get the chain fixed so I can ride this thing around for at least 1000 miles til next winter!! Should I just order another master link and try my luck again? If I could find a master link that has those protector things that prevent you from overtightening the master link (I think you slip em in line with the orings before you put the end plate on) I'd feel more confident. I don't want to try a clip-on master link... I barely trust those on my bicycle...
What do you guys think. Would this go away if I gently ran the bike a little? I've taken a little screw driver and filleted the end plate off a little bit so it's not too tight, but the thing still looks kinky. Like I said I haven't riveted the peen things in permanently... I hope to god I didn't f*ck up the last two chain links touching each side of the master link, like I made those guys too tight from pressing in the master link. You see how paranoid I get? That's why I f*ck up stupid little **** like this!!
Just looking for some oversight here. Thanks kindly
Forgot to add: bike is a '95 F3. Has about 23K and change. No idea if prev. owner ever changed the chain out, but judging from what it looked like, I think it was still the original (yikes). I figured it would be best to change the chain because it was REALLY slacking bad (2-3", I think spec is 1.5" up and down).
It won't get any better. Trust me on that.
You really need to grind out the pins and start over with a new master link.
You can't go by the factory staked pins as a reference for the master's rivet pins. The chain box should tell you how many mm's to to splay the rivet heads. If not, in the past, I've just tightened a little at a time and remove the tool to flex the chain and check the rivet head.
:plus1:
To what Jon said. That just looks like it does not line up at all. You could lube it up and take it for a short very slow ride but,... I would start over with a new master link. Does it pivot/flex by hand on each side of the master link?
If your not flogging the crap out of the bike maybe use a clip on master link. Also, just because the chain had 3 inch sag instead of 1 1/2 inches didnt mean it was any wore out more than the sprockets. Should've just adjusted the slack and save your money for a complete chain and sprocket kit.
Heeza Y Zasch
Judge me if you like, but I've been using "clip style" Masters without problem for decades. I'm not the smallest of riders, and I think my riding style is "middle of the road".
Additionally, since clip Masters are only about $5, why not go buy two, pop that bad-boy out, and have a spare on hand :thumb:
Those are my two pennies. Good Luck.
I agree unslow1, we used clip style for years. Even racing in the mid 90's. Clip, safety wire, and smear a thin layer of silicone over it and you were good to go. Passed Tech Inspection and all.
I had a clip type master link come off my race bike at the fastest part of Road Atlanta...the old Gravity Cavity. The only thing that prevented me from having a horrible crash was the (LUCKY) fact that the chain simply fell free of the bike and slid across the asphalt. It could easily have wrapped around the rear wheel, and at 160 mph, that would have been disastrous. Rivet only for me, TYVM.
The "old gravity cavity" Did two weekends at Road Atlanta back in mid to late 90's on my F2. Awesome track, amazing amount of traction, especially compared to the "smooth as glass, slick as snoot" Summit Point at the time.
I never made it to Summit. I lived in MD before I started racing, but it's reputation kept me from trying to reach into Mid-Atlantic. :D I've lived in North Georgia since '75, started racing in '86, and have a LOT of miles on the old Road A. The new 10A/B is still a challenge, but it doesn't make you grunt out loud in your helmet at the bottom any more. :D :D :D Good times :)
1 - 10 of 10 Posts
