1 - 20 of 37 Posts
· Registered
Guess I just can't help myself. Saw a non-running 07 shadow for sale and thought I'd take the opportunity to tear down my first bike. It only has 11,500 miles.
The previous owner decided he wanted to strip and paint the gas tank and front fender a satin black... Out if a can... So that's terrible but an easy fix. He also said 2 years ago it started running poorly so he took it to the shop, spent $600 on a carb rebuild and coils, still ran like crap so he bought a new bike.
I guess he had enough of it sitting in his garage so he listed it for sale. Battery is dead and he didn't care to charge it so who knows it it'll run. I popped the crank cover off and rotated the engine to make sure it wasn't seized and walked away with a bike for $800.
Land vehicle Motorcycle Vehicle Car Fuel tank
· Registered
Discussion Starter · #9 ·
I think those were from the rebuild kit. The PO had all the jets they took off. They show their age but are clear and not as beat up. Thought about swapping back to them since they're not chewed up.
· President: Team Full Chat
Love the documentation! Keep it coming! I've done a lot of work on Shadows over the years, they were ALWAYS easy to tune and get running smooth. They have hydraulic tappets and never need adjusting. I hope the running issue is just an air/fuel screw adjustment or poor fuel.....
· Registered
Discussion Starter · #11 ·
I was going to check valve clearances but when I looked up the procedure, I saw it had hydraulic adjusters. I did see you could shim between the rod and tappet though and sometimes there are issues with the valves seating.
· Registered
That much oil in the airbox is a BAAAAADDD sign man. Have you compression checked it yet. It's probably got an internal seal out or bad rings.
I'm thinking you should have ran from this one. Hoping for the best for you man, but don't be afraid to cut your loses because you could be sinking alot into this bike unless your going to do it all your self. Good luck.
· Registered
I hope not. The way the story sounds though is the bike might have low compression. Would explain the still running like crap after the carb work from the dealer, and the residue in the airbox, and it sitting for 2 years while the owner tried to figure out what to do with it, because dealer repair is probably more than the bike is worth. I would definitely compression test it.
· Registered
Discussion Starter · #16 ·
changed the oil and checked compression. the oil level was way high, smelled strongly of gas and was the same viscosity as was in the air box.
compression spec is 185psi +/- 28. front was 165, rear 175. that all seems fine, not sure how so much gas got in the crank case. oil capacity is 3.3 quarts at filter change. I drained about 5 quarts today and the quart from the air box, that's nearly a gallon of gas mixed with the oil. i don't know how that could happen and there still be good compression.
· Registered
Discussion Starter · #19 ·
Changed the plugs, clearly oil fouled as expected from the GALLON EXTRA. The front one also looked like it had been running lean, which is also expected due to the float being too high.
Rear plug
Front plug
Put everything back together and cranked her over. Fired right up, and idled after she warmed up but noticed an exhaust leak out of the back cylinder. Hopefully it's just the gasket and not the wall of the header.
1 - 20 of 37 Posts
