I've just bough a 2nd hand bolt on micron exhaust / muffler for my blade 954, it has all the fittings except the gaskett.
My question is - can i use the original gaskett that is with the original honda exhaust that is on at the moment? Or will i have to purchase an micron gaskett.
What im basically asking is are they the same or different??
Thanks
if the old gasket is in decent shape and it fits use it. i didn't use a gasket when i replaced the exhaust on my old 954, there was a pretty good fit already
The old gasket should work fine, You can by a new stock one if you wish. I reused mine on my 900RR when I changed to bolt on to a D&D
Hey, do you notice with your D&D slip on, if it is just a slip on can...that you get a little boggy-ness off the line until about 6K RPMs...I bought a K&N filter I havnt fitted yet to try to fix the problem...anyway sorry to hijack the OP, but as for that I would, if its clean reuse but a replacement cant be that expensive either...
I never experienced any problems with the D&D, I had the needles raised in the carbs about 2 mos. after in installed the slip on, And I have been running a uni filter for years. Never had a bogging problem at any RPM
Thanks...I don't know what it's like without it... My bike has always had it, perhaps I'll adjust the carbs this winter
