1 - 11 of 11 Posts
connect the wiring harnes, then locate the service check connector, conect between the two terminals with bare wire to make a loop, turn on the ignition-the servo should turn, then stop. when it stops insert a 3x28mm bolt or pin into the hole in the top of the servo pulley to lock it into position. turn ignition off, then connect cables to the pully in correct order.Adjust cables then remove pin. remove check connector. and away you go.....:thumb:
1 - 11 of 11 Posts
