I noticed today the the right hand engine bolt is missing.
I'm just after some advice on the right part numbers as the microfische is not completely clear. Could someone confirm that the follwing parts are correct
Bolt
Bolt Flange 10x47 90180SF4010
Washer
Collar, Front Upper 50358MW0000
many thanks
Sure it's missing.... And the head hasn't gone leaving part of the threaded shaft in the bolt hole....???
I'll extend this offer to anyone on the forum. If you give me dimensions and I have the bolt/nut/fastener in my pile of accumulated motorcycle bits, I'll send it free + shipping cost. I'll limit the offer to first 2 requests per week as I have a real job and two kids taking up my time.
PM or text specific needs.
Later,
Kent Larson in Minnesota
Text to: sex 1 too ate 6 eight 3 for 1 fore (I pretend that fools the net-bots)
Take time, think twice to avoid messing up once......
Possible suggestions would include...
1) drill out with small enough drill to avoid damaging the thread, large enough to use a stud extractor...
2) use a quality drill bit and stud extractor (lubricate the drill bit as you go)
3) plasticine to create a well to soak the stud with penetration oil....
4) heat might break the "seal" most likely formed by corrosion and prior heat...(perhaps a small gas soldering iron will give sufficient heat but also controllability)...
5) good mate to hold the bike steady etc...
6) Be careful of the frame, wiring and petrol tank/pipes.....
Of course, you probably know all this already....
Have fun....
