Hi,
has anyone cut the baffle plate out of a stock can? if so what were the results like? more top end? any loss of midrange? I would think the HTEV would take care of back pressure issues, obviously the pc would need a new map to make the most of it.
I'm just after a bit more noise
any input is appreciated
cheers
Ben.
The only reason I removed mine was so my Two Brother's slip-on would fit. Sorry, no noticable gain in power with the slip or the cone cut off. Instead of worrying about trying to gain a few HP, just go out and ride.
You're very likely to make the bike sound like sh!t and it's very unlikely that you'll find any gains in power whatsoever. Even well engineered, straight-through 'race' type bolt-on canisters only net a couple hp extra on top.
If you want the bike to sound better, simply save your pennies and get yourself a decent can when you can afford it.
Tank69 : The only reason I removed mine was so my Two Brother's slip-on would fit.  Sorry, no noticable gain in power with the slip or the cone cut off.  Instead of worrying about trying to gain a few HP, just go out and ride.
You're talking about the cone, and he's talking about the baffle plate; two very different things.
righto not worth the hassle then.
I'll leave it stock in that case- thanks for saving me the hassle of finding out the hard way
Ben.
