hello. bike is fine will shifting threw other gears, except 2nd kicks out EVERY time.... Anyone know why this is?? any help please...
The dogs on second gear are worn.hello. bike is fine will shifting threw other gears, except 2nd kicks out EVERY time.... Anyone know why this is?? any help please...
You should be able to skip past second with no trouble until you're ready to pull the engine out. Since it does it all the time it's likely the shift fork is also bent from trying to force it to stay in so be sure to check those as well.
if the transmission is good along with the gears,forks etc. and assuming you know what your doin then yesthanks for the responses.
if i bought a transmission with the drum, gears, forks, bearing and installed that woud that work??? i found one in good condition for $150 on ebay.
Gears?No need for the gears or drum. I'd advise against used transmission parts other than those ones, too.
Its not everyday one splits the engine, might as well pay a little extra for the peace of mind.
Search, as a few guys have posted threads about doing theirs themselves.How hard was it to get the transmission out? i know a thing or two about bikes. good with tools, but would like some input...
