A simple solution may be to check fuel flow to the carbs. Fuel filter may need replacing or just bad fuel (water in fuel). Air filter may be dirty. Process of elimination from simple to more complicated.
Bit vague there bud.
First you need to find out why it is cutting out - is it electrical or is it fuel for example.
Have you got carbs or Fi?
Could be anything from a bad fuel to bad electrical connection and anything in between. If you could give a bit more details, such as what happens, when, whether it stops completely or its spluttering, etc, the more the better................
@Tony liccp no mystic megs on here I'm afraid 🤪
As stated above try signposting what happens and what doesn't happen?
For example:
When it cuts do the eletrics stay on?
Is it when it's hot/cold?
Does it start straight back up?
I can honestly say between the several regulars on here there isn't a "cut out" we haven't all felt first hand.
