So i bought a new battery thinking the old one was just not holding a charge, but when i put it in the bike it did the same thing, it wouldnt turn over for to long and the more i tried to start the bike the more the battery drains, it took about 5mins for a fresh battery to drain while trying to start it and i honestly dont know what the problem is or could be
by the way the bike i am having this problem with is a '94 CBR900RR
The charging system is not working.
Charge the battery up and then do the tests of the charging system to determine if a component has failed.
most common problem is The regulator/rectifier, you can buy them cheap online. if not then its your stator... there are ways to test them on here. search and you will find it
