I’ve just bought an nc23 baby blade which is fantastic, only problem is the gear shifter , I could do with it being a bit longer so I can move my foot easily to downshift are there any longer ones available or would it be a custom job??
:oops:Yup mine are only size 8 , can only suggest raising or lowering the pedal height till you feel comfortable with
👍 gonna see about getting a longer lever or making a custom one , also the speedo doesn’t work , any thoughts??
Could be just the cable, check the 2 securing knurled caps each end, or just take out the cable at the engine end and spin the cable to see if you have movement on the speedo, sometimes riders open up the clock to release the limiter mechanism and bugger up the speedo
