Hey Bladers,
I desperately need to change the chain on my 1993 900rr! But I'm a little confused on what to look for. I would like a gold chain and thats about all I know for sure. I keep seeing on ebay "520 chain sprocket conversion", arn't the 900rr's already stock with this setup? Ugghhh! Any help bladers would be great!
Jeremy:idunno:
520 is one tooth down in front sprocket and two up in the rear from your stock setup. gearing is changed and it will give u a nice acceleration boost. one of the better mods u can do to your bike.
Sorry, but you're 100% wrong here.
520 is the size of the chain. The units are 1/8 of an inch.
5 is the distance between chain rollers, so 5/8 of an inch from one roller to the next (also known as length of the link).
20 is the width of the chain, means 2.0, so 2/8 = 1/4 of an inch wide.
The gearing is completely independent of the chain size. A narrower chain is lighter, so you get very slightly better performance - but not worth it on the street IMO.
