1 - 2 of 2 Posts
I have inherited a 96 CBR600 F3. The speedo will start at 15mph the slowly go up until it finally maxes out no matter how fast or slow you are going.:eek:
When I unplug speed sensor there is no change in the way the speedo acts. If I unplug the harness from the speedo it still acts the same. If I unplug the Tach harness the sppedo apparently lose all electrical and goes back to zero. Not sure if speedo power is supplied through tach harness or not. Anyway it does not appear to be speed sensor issue but rather some type of voltage issue. Speedo will continue to slowly increase speed even if bike is stationary and not running but ignition switch is on.:thumbd:
the bike needs a new cluster assy, most likely it has had some water seep into it , the cluster is all interconnected together.
1 - 2 of 2 Posts
