1 - 2 of 2 Posts
Hello....Recently bought an 06 cbr 600rr. needs a little cosmetic work but overall hoping it will be a good bike. Only one problem....When you hit 35-40mph it feels like it starts to bounce around almost like the motor is cutting out. It is lowered and stretched. Could this be the problem? Also i think the front rotor has a bad spot in it but not to sure that would be the cause of the bouncing. Not a new rider but never had one lowered. Anyone had this problem? Thanks for any help!!!
:welcome: to the org, maybe they stiffened the springs up that may couse the bounce, and i would start with the plugs, check all wire connections, and im sure someone else will give you good advise, good luck
1 - 2 of 2 Posts
