1 - 9 of 9 Posts
I'm looking for a 43 tooth rear sprocket for 2000 929. I would prefer steel, but Alum. would be fine. The chain is stamped LM520 90X. I would like a set(front,rear,chain) new or used in great shape. Funds are tight right now so I dont want to spend over $75-100 tops. The set I would like is 15t frt., 43t rear, 520/530 chain, alum or steel. open to other set-ups. Thanks
Im parting out my 2000 929 and have some sprockets and 520 chain. I will check the teeth numbers and let you know. Frt and rear. Rears are alumin. All in good shape
Sorry on the delay. I got the sprocket numbers now. I have 2 rear sprockets a 46 and a 48, both quality aluminum ones. the front is steel and is 15 teeth. The chain is in good shape, is gold and says " 520VD" on the side plates. I have always over lubed my chains so they don't wear much if any. I use Tri- flow teflon spray on them. Let me know if those will work for you.
that's the setup I want. what would you take for both rears,front,and chain with shipping.
1 - 9 of 9 Posts
