1 - 20 of 31 Posts
new here, just picked up my first sportbike last week its a cbr900RRs ? whats the s for? ive heard of cbr900RR but not RRs, well anyways how do you upload pics? i need some help with wiring and other stuff, i see nowhere to hook up a rear breaklight i have a red led strip light on the rear and turn signals but no rear brake light, also need some help on wiring today my speedo randomly started bouncing, im familar with cars but not so much bikes, in my old integra the speedo would bounce in neutral or revving like how my bike is but it was a ground wire that wasnt hooked up properly help anyone? ill post pics of her as soon as i find out how, i started polishing her today. her name is bitch cause shes my bitch and does what i want
Discussion Starter #2
pics of her. need new fairings and a headlight the guy i got it from treated her like **** idk what kind of plastics are on it but its hideous. i he cut the rear plastic and duct taped a seat on. also does the battery lie down flat under the rear seat?
as you can see in the last picture my harness looks like crap i ordered a manual for it already but have to wait for it to come in if someone can help me till then it would b great
The S indicates the '95 model year.
alright cool thanks, well i guess ima use this thread as a place to keep updates of my bike....hope ppl comment and help me with technical issues i might encounter
previous owner had ductape and foam pad for the seat he also cut the hell out the rear piece so there wasnt enough to salvage so i got a old t shirt for now and pop riveted it on for now since im broke and its going to b a stunt bike practicing on it almost daily, also cleaned up the harness so its not hanging how it was in previous pic but everything is still connected, what you guys think?
Has it got a 17" front wheel?
I actually think the fairing with the small headlights looks pretty sweet. A shiny new paint job and you will have something different.
yes it does blade racer, chrisjlaw the headlights are autozone lol they are cheap looking and tacky the holes were also cut by the previous owner and they arent even round its choppy, i couldnt turn much either because the fairing so i cut some of it off ima replace them anyways, i hit it with fresh black paint but ima get new fairings soon i just want to be in the wind now lol
so shes not starting! im pretty sure my fuel pump died, tried another and she still kept dying, she would start with choke on but died as soon as i took off the choke, also the turn signal fuse thing keeps clicking?? i just wanna ride i hope someone can help me out, been hella depressed lately and riding is my only escape!
Bypass the pump, but my guess is the carbs need stripping and cleaning.
What do you mean it "keeps clicking"? As soon as you turn the key on?
Is the battery charged up?
do i need a rebuild kit or just take them apart clean them and re adjust them? as soon as i turn the key on it sounds like i got the turn signal on but they arent?
I think you can buy aftermarket kits but they probably just need cleaning.
Strip out all the jets, chokes, float valves and mixture screws and clean everything with carb cleaner and compressed air, making sure that carb cleaner flows through all of the orifices as it should.
Shouldn't need any adjustments.
Hook up a fuel supply before installing them and make sure they don't leak when held as they would be positioned on the engine. Then tilt them each way until they overflow and confirm that they stop overflowing when you right them again.
No idea about the relay, is the battery charged?
Discussion Starter #14
yes the battery is charged the bike was running fine before a couple days ago, i was riding and it randomly stopped working pretty sure fuel pump gave out cause it wouldnt take any throttle at all it would die as soon as i give it gas. still doing the same thing
Then bypass the pump.
i have a petcock that has a vacuum line hook up where do i hook that up?
Then you shouldn't have a pump.
Is the vacuum line connected to the engine or carbs?
Discussion Starter #18
so take the pump out? it used to have a gravity feed with a fuel pump the petcock was leaking so i ordered a new one it has a line for vacuum, im not sure where to hook up the vacuum line up to
Discussion Starter #19
also the throttle has no return what so ever it feels like it has cruise control ive had dirtbikes before and they always wanna snap back if i let off the gas, is this normal on a street bike? like i can literally take my hand off the throttle at any speed even freeway speed and it just kinda stays where its at it
The pump will prevent it from gravity feeding the carbs.
If you keep the pump then you can usually swap the spring to the other side of the vacuum diaphram so it stays open, and clamp off the vacuum line.
If you want to use the vacuum diaphram then you need to connect the vacuum hose to a vacuum port on the intake manifolds, usually one of the synchronisation ports.
1 - 20 of 31 Posts
