Just had somebody install pirelli diablos on my cbr 929 and i am trying to fit the rear wheel on but the tire touches the swingarm and still doesnt have room to fit the chain around the sprocket. what happened? tire to big?
The tire size wouldn't affect the chain not going on. Is the chain possibly kinked up at the front sprocket? What size tire did you put on it?
What size is your rear sprocket?
What size tire came off, and what is your new tire size?
You may need to add a link to your chain to accommodate a taller tire. Did you go from a 50 series to a 55 series?
Heeza Y Zasch
without knowing whether or not you changed from OEM size tire (and/or rear sprocket teeth) I'd guess that your spacers (SIDE COLLARS) are on backwards.
double check with your service manual, ensuring the "top hat" collar is on the DRIVE side and the smooth collar is on the brake side.
