1 - 15 of 15 Posts
Hello all. I'm Jim and this is my first post. Hopefully you'll be able to help me fix my 94 cbr 900rr.
I went to start it today and the starter sounded like it had a problem. On removing the generator cover it seemed ok. This is where my limited knowledge fell short. The starter is turning the smaller cog which in turn is turning a larger one (flywheel?). However there is no real purchase if you know what i mean it is just spinning. Something is not engaging properly I reckon, but I have no idea what it is. Your help and advice would be much appreciated, cheers, Jim.
sounds like the starter is not throwing out, take the starter off and clean it up, Never had one apart myself, but recon it must be the same as a car starter...oh and :welcome:
Discussion Starter · #3 ·
Hello Rick. I take it ITFC is Ipswich if so nice one I support em too. Not easy this season though. Nope starter is turning , that is turning the smaller cog which is positioned to turn the flywheel which is also turning. But that is where it all goes wrong there is no purchase and it doesn't sound like it is going to start. They just all spin freely.
Discussion Starter · #5 ·
Yeh Rick that's right. All spinning fine. But it just makes a high pitched whirring sound. Not the usual deeper sound, like there is no purchase etc. Clutching at straws now to be honest mate.
sounds to me like the starter clutch is faulty,best way to check is remove starter, then as you look at it through the hole, check that the idle/reduction gear rotates freely clockwise, but locks when you spin it anti clockwise, if not the starter clutch is faulty..
As you pull the starter out, as you look through the hole it should move freely clockwise and lock antclockwise. Main thing it should only move in one direction.on my 929 the starter clutch is behind the alternator rotor. There are things called sprags they may be damaged, you will have to replace them. bit to complicated to explain on here, so best to get a workshop manual and follow it.. but check the starter clutch first.
Thing called spraggs, they can get damaged and just need replacing, but if i was you i would invest in a manual for when you strip it down as its a bit to complicated to explain, but not difficult to do. At least you know what it is now:thumb:
1 - 15 of 15 Posts
