i have a 94 cbr 600f2,i started it up the other day,then it stalled when i gave it a little gas,turned the key off and went to turn it back on and nothing..i was wondering if it could be my ignition switch,it is cracked,i checked all my fuses and i know my battery has a full charge,thought maybe the kill switch,but i have absolutlely no power not even headlights.
Discussion Starter #2
Re: no power at all
I FOUND OUT WHY NO POWER,BLOWN FUSE,NEAR BATTERY(30A),THINKING ITS THE REGULATOR RECTIFIER,NO BARE WIRES ANYWHERE BY THE LOOKS,AND IT KEEPS BLOWING FUSES.
Re: no power at all
ANOTHER QUESTION....I HAVE A DENTED GAS TANK,AND IT LEAKS OUT OF ONE OF THE AIR HOSES WHEN IT GETS OVER HALF FULL..ANY IDEAS?
I used a crescent wrench. Remove the tank and crank it down. The hard part is making sure your valve body lines up with the hole in the fairing. I used a piece of tape to mark the angle I wanted the valve at. Check all the petcock o-rings and washer while you are at it though.
