1 - 2 of 2 Posts
I had a dead battery and tried jumping my 954 today. It turned over and fired and then everything went out. Checked all fuses by the battery tray and all are good. Where should I look or try next. Please say I didn't fry anything computer related. Thanks
When you say you "had" a dead battery do you still have a dead battery?
If you have nothing at all then measure the voltage across the battery terminals to confirm you do have power.
Then confirm the battery terminals are tight.
Then check the main fuse on the starter relay.
Then check the ignition switch connector and that you are getting power at the switch.
1 - 2 of 2 Posts
