Hey all! I had an account on here way back and can't, for the life of me, find my username even when using the search bar. Anyway, I had a 1994 CBR900rr that died on me a few years ago. I sold it because life dealt me an unfortunate hand at the time. I do remember IanDoohan and Duncan893 trying to help, though- your usernames look familiar! Glad to see you're still around here.
I found a 1995 CBR900rr for sale for $800 and trucked it home in my pickup. It's gonna be my baby, since I had to give that other one up. Its condition:
With a new battery, the bike turns over strong in neutral. The starter relay clicks and sounds normal.
I figured I'd wire the pump up properly again and test it to get fuel into the engine.
So I wired it directly to the battery, and it pumped fuel.
I connected the pump to the carbs properly. I turned it over and engaged the pump directly to the battery after a few seconds.
I know these can run without pumps. Since my tank doesn't have a vacuum petcock, I connected it directly to the carbs and opened it up with fuel in the tank.
I took out a spark plug and grounded it against the engine.
I checked the battery voltage at the CDI and found it to read normal.
I checked the pulse generator resistance at its connector and found it to read normal. I HAVE NOT CHECKED THIS AT THE CDI.
I bypassed the clutch switch by connecting both ends to a 10A fuse.
I bypassed the side stand switch by unplugging it.
I tested and confirmed the neutral switch to work at the CDI, and found it to work.
I found the kill switch to work properly- MAY HAVE TO CHECK AGAIN.
I tried grounding all four spark plugs at all four plug cables.
I ordered new CR9EH spark plugs, then tested a new one at all four locations.
I checked the resistance of the coils.
The coils themselves seem to be normal. This led me to check the small gauge wires leading to the coils on the coil end (not the CDI end).
The manual states that if none of this works, then my CDI is bad, so I ordered a CDI from eBay.
They are both for 1995 CBR900rrs... but mine has a different connector. I've attached pictures. The labeled one is mine, and lacks that little curve in the bottom right corner. The pin holes are different too.
Should I spend the money to test a different CDI? I'm returning this one.
Does anyone have any other ideas? I'll check the pulse generator, coil, and kill switch connections at the CDI but I have a feeling none are grounding right now. This is killing me, haha.
- Not running.
- The battery was fully dead
- The fuel pump had some interesting wiring that bypassed the relay with a general hardware switch
- When plugged into the proper connectors and the starter pushed, there was no priming or running.
- The fuel relay must be dead.
- At some point I'll swap that relay with the turn signal relay since they are said to be identical.
- No burn.
- No burn.
- So it is not the pump.
- No spark. THIS IS THE MAIN ISSUE. NOTE TO SELF... CHECK FOR SPARK SOONER NEXT TIME!
- I then grounded it against the battery's negative. Still no spark.
- No spark from any plug at any location.
- It's possible that they were all fouled.
- No spark.
- Roughly 2.5 ohms between the small-gauge wire connectors on both coils. I HAVE NOT CHECKED THIS AT THE CDI.
- Roughly 21 k ohms at the plug ends of ONE coil, and ZERO k ohms at THE OTHER coil's plug ends. These cable are probably bad.
- Roughly 13 k ohms at each coil with the spark plug cables REMOVED.
- I get 12 volts when touching all of the wires individually to one end of the multimeter and the other end to the positive of the battery.
- I get continuity to the ground at all four of the wires.
