I can start my bike and let it run for a while and the needle of the temp gauge does not even move up to the C. Would this be the thermostat or the temp sensor.
if the radiator is hot... it'll be a faulty temp sender:D
is there any coolant in there????
wont work if its empty!! so first thing to check is that..
then the feed to the clocks and then the sensor.
had everything broken down when i posted since i was almost sure it was the temp sensor so pretty much i was fixing the problem while i was asking just in case it could be something totally diffrent from the temp sensor....
