Hi Guys new to the forum just back from a ride out on my rr2 fireblade when i`m in 3rd gear it has a rattling sound coming from it sounds if the chain is slack but it aint no sound in any other gear goes away when the clutch is engaged. can anyone shed some light on my problem
Thanks
What shape is your chain and sprockets in? Is it at any rpm in third? Under power or cruising? Try duplicating the conditions in other gears. If its cam chain or drive chain, you should be able to have it happen in other gears.
Hi
My chain & sprockets are fine no matter what speed, cruising or full throttle the sound appears when 3rd is engaged dissappears right away when 4th or 2nd is selected
Well, it certainly looks like a trans issue whiz. Does third stay engaged ok while under power without skipping out? It is an odd sound though that's why I thought we better investigate further. I think you know what's involved now. Sorry man!
