1 - 9 of 9 Posts
Hopefully an easy question! Are the nose cones on a 96-97 the same as 98-99, i.e. are the lights the same?
The mounting points are the same. If you got a 96-97 nose, you could swap the headlight and fairing stay and be fine.
Partially true Skant, the 95-97 US models share the same upper fairing stay, headlights, speedo, and speedo bracket. The 98-99 speedo bracket is different, longer, and has a an angled front mount. The mirror bracket is also slightly tweaked so may not line up perfectly, and the 98-99 headlight is a different shape.
Who said this was an easy question :) So what I am really after is if I have a '97 and use a full fairing kit for a '98 will the lights etc. fit ?
1 - 9 of 9 Posts
