1 - 9 of 9 Posts
I bought a CBR954 in parts to rebuild so I never heard it run but the guy spun a rod bearing. I fire it up after the rebuild and I'm getting this ticking noise. I've checked and re-checked the valves and the clearances are perfect. I replaced the CCT with OEM but it didn't help. Using a stethoscope it sounds like the noise is coming from somewhere near or around the head but I can't pinpoint a location. It seems about the same on both sides. The bike did not come with the air box flapper or HTEV exhaust valve and has aftermarket velocity stacks. Could this be making excessive valve noise? Anyone notice a difference in sound after removing the HTEV system? Aside from the noise the bike runs great. I wouldn't mind it so much if I wasn't planning to sell it.. Thanks in advance.
First off that bike is clean and looks great. I love everything being properly PC'd black. Secondly the ticking sound to me sounds like it is coming from possibly the valvetrain.
Can you go into more specifics about the rebuild such as was it bored, honed, pistons, etc. etc. These bikes have very temperamental cct's but you did say you replaced it with OEM. If you find something let us know and GLWS.
Thanks. The previous owner did a nice job making the bike look good but apparently didn't take care of the engine. I'd love to keep it but can't justify a 929 and 954.
Anyways, it has a new (used) crankshaft, new (new) no.3 conn. rod, and new rod and journal bearings. The cylinder walls showed typical wear so those were just honed and I installed new, standard sized, piston rings. I cleaned all the carbon from the pistons and valves and lapped the valves but left the original valve guides. I didn't notice any excessive wear on the head but I wasn't paying too much attention (i.e. I didn't measure the valve springs or inspect the cam lobes) since the bike only has ~13k mi. I have also replaced the throttle body thinking it might be the injectors and it needed a new FPR anyways. New spark plugs didn't make a difference either. I'd hate to dump any more money into new parts and still not be able to solve the issue..
Mine does tick like this but when knocked into first and ridden a hundred metres or so it goes away, it did this before and after htve removed and air box flap. Nice colour bike btw
Thanks 327! I was hoping this was caused by the HTEV system removal but I wasn't really convinced. It's not that noticeable while riding but is there at every stop light and such.
I've checked the valves with feeler gauges literally three times, thinking something bumped loose, and they are all within tolerance. I also bought new exhaust gaskets but that didn't help.
I backed out the CCT today to see if it was fully extended but it still has some adjustability which leads me to believe the cam chain isn't too worn (I hope!). Back at it with the stethoscope and it seems like it's loudest coming from the thermostat. Also, 100% of the time the noise goes away between ~98-108 degrees F. I must be going nuts, I don't see how the thermostat could be causing this.
I've had quite a few Fireblades and I would have to agree that the Cam Chain and CCT are both worn. have you tried backing the CCT out? What you can do is loosen the 2 bolts (NOT ALL THE WAY) but just enough that you can hear the splines clicking as you back them out. It should allow for the CCT to tighten up against the Chain. start by only going 3-5 clicks then tighten it back up and start the bike see if that helps if it still ticks only go 2-3 more clicks out if you go to far the bike will make a crazy little cry baby whine sound NOT GOOD that means the chain is way to tight
1 - 9 of 9 Posts
